mfa
172
10-07-2019 09:54 AM
Highlighted
Looking for information on using Enterprise Login with MFA - anyone using this?
Thanks in advance.  Ellen
Tags (1)
Reply
Highlighted
Ellen,
Are you using ArcGIS Online or Portal? Portal does not currently allow multifactor authentication in the same way that ArcGIS Online does. According to the Geonet post below, you can achieve multifactor authentication by configuring an identity provide that supports MFA, such as Okta.
https://community.esri.com/thread/211301-two-factor-authentication-on-portal
-Josh
Reply
