How would I add a geotiff to an arcgis online map
2609
13
04-27-2017 09:09 AM
Highlighted
I have some Landsat 8 imagery from LandViewer that I'd like to add to a map. Is this possible with the educational online account?
Reply
Highlighted
Esri Esteemed Contributor
Hi Cassie,
The image would need to be published as a service (i.e. ArcGIS Server services, WMS, Tile Layer, etc).  You would need ArcGIS Server or an ArcGIS Online Organization account to create a service from the GeoTIFF.
Highlighted
Thank you Jake,
I have a ConnetEd account for ArcGIS online. That probably isn’t robust enough, is it?
Cassie
Reply
Highlighted
I'm not familiar with a ConnectEd account.  Do you have a 'My Organization' tab at the top when you sign in.  Ex:
Reply
Highlighted
Yes I do.
Reply
Highlighted
Great, then you have credits and you will be able to create a Tiled Service.  Here is a document you can follow with steps on how to do this:
https://community.esri.com/docs/DOC-2996
Highlighted
Great, thank you. If I read this correctly though, wouldn’t I need a desktop version of ArcGIS first?
Cassie
Reply
Highlighted
Yes, you need ArcGIS Desktop to create the service from the GeoTIFF.
Reply
Highlighted
Any options for just the online account?
Reply
Highlighted
Unfortunately, I don't believe there is.
Reply
