Field is being read as a text string when it is numeric
1794
5
09-18-2017 08:04 AM
ScottLynch
Using ArcMap 10.5.1
I'm new to ArcMap and I imported a table into my map and then displayed the XY data. I am using proportional symbology to represent the error within the data and it worked smoothly for every data set (I have error represented in a field with a number indicating meters) but two of my sets (whose source data is identically formatted to all of the others) read my error field as a text string. It is literally a number with no text in the field (save the field header) and when I go to change it the box is grayed out, indicating it can't be changed. Is this a new user error on my part, or something others have run into?
Thank you for your help.
DanPatterson_Retired
MVP Esteemed Contributor
If the field in the featureclass table is left-justified, it is being treated as text, regardless of they are numbers or not.
To ensure numbers, explicitly format in the originating program to ensure that only numbers can go into a column.
A space in a record for a column will translate the whole column to text
Try not to use a spreadsheet unless you have read the help documentation on using Excel
ScottLynch
Thanks for the help. Attempting this fix now. I was given basic lessons and I was taught to use Excel. I didn't realize it wasn't the optimal file type to use.
Jayanta_Poddar
MVP Honored Contributor
Could you attach a sample of the concerned XY table?
RobertBorchert
Frequent Contributor II
When you imported the table it automatically made it a STRING field.
As a workaround you can create a new COLUMN and make it a LONG INTEGER,   then populate it with the original field.
JoeBorgione
As Robert Borchert‌ suggests, add a new column as a long int type.  Using the field calculator set to python, calc the NewColumn = int(!orginal_field!)
can't wait to retire....
