Error 000354 in create a new feature class?
226
04-24-2020 11:04 PM
SiqiHuang1
Hi!
I am working with ArcGIS Pro. I am trying to use an insert cursor to create a new polyline feature from a list of coordinates in pythonWin. Here is what my code is. Could anyone tell me what am I doing wrong or missing?
Thank you!
Reply
DanPatterson_Retired
MVP Esteemed Contributor
code formatting should be used
/blogs/dan_patterson/2016/08/14/script-formatting
If you are creating a featureclass, you need to specify *.shp if a shapefile is required and its destination is a folder, otherwise, you need to specify a geodatabase location.
Also, you need to "raw encode" you paths if using a single backslash
eg... r"C:\YourFolderPath\AnotherFolder\A_geodatabase.gdb"
Create Feature Class—Data Management toolbox | Documentation
Reply
