Connecting point attributes over an polygon with an other point
136
08-23-2019 01:54 AM
Highlighted
Hi
At the attachment you find a gdb with 2 point- and a polygon-shape. One point is a sewer the other are attributes. Both layers are from a CAD-file. At the CAD-file are no logical connections between both layers. I loaded the data to GIS and drew polygons around both layers.
I tried merge, spatial join and other functions but I can’t connect the data that I get all attributes over the polygon to the point of the sewer. If I use spatial join I get only many polygons (for each point one polygon).
Do you know a smart way. I have 600 sewers and I don't want do it manually.
Test_DATA.gdb
Gerrit
Reply
Highlighted
I have moved your question to the "Education" space, from the unrelated project where it was originally posted.
Reply
