Combine attributes of tiff layer file and the shapefiles they fall into
111
07-23-2019 07:30 AM
Highlighted
I am currently using ArcMap 10.5 and having trouble combining information of two layers. One is a tiff file with land classification data, and the other is a shapefile with broad scale regions. Is there a way to combine the two layers so that the attribute table for the tiff file lists which of the shapefile regions it falls into or the percentage of cover for that specific shapefile?
Reply
Highlighted
MVP Esteemed Contributor
several options...
Tabulate Area—Help | ArcGIS Desktop
would be a good start.  There are also other options within the spatial analyst tools if you have it and there are several incarnations of "Summarize Within" ie
Summarize Within—Help | ArcGIS Desktop
Reply
