can't find amazon ecoregion in arcmap tutorial
362
10-20-2017 06:31 AM
Highlighted
So, I'm trying to take the free "Getting Started with ArcMap" tutorial. The first step is going to "Add Data" and then "Add Data from AcrGIS Online" and search for the Amazon Ecoregion map by Learn_ArcGIS - except that when I search for the Amazon Ecoregion nothing by Learn_ArcGIS comes up. There is not Amazon Ecoregion I can download to my Arcmap. What's going on? Can I fix this? Thanks.
Highlighted
MVP Esteemed Contributor
Based on a similar question related to tutorials...
Did you download the tutorial data? and unzip/install it if needed?
Highlighted
Actually, turned out the tutorial needed a different version of ArcMap. Thanks tho!
Highlighted
@Theo Sweezy I've faced the same problem while needed to access amazon ecoregion map. But I solved it by uncheck only search in [username]
Reply
