Calculate Solar Radiation Raster TOOL
1706
8
03-06-2017 06:53 AM
HishamAlghamdi1
At the second 23 in the video below:
Calculate Solar Radiation - YouTube
You will see "Calculate Solar Radiation Rasters"
I search a lot to find this tool in the Geoprocessing tools but unfortunately I couldn't find it.
Does anyone know how to get this tool please?
Appreciate your helps in advanced.
DanPatterson_Retired
They are in ArcToolbox.  You have a view from within ArcGIS Pro, but they exist in ArcMap and the toolset requires the Spatial Analyst extension.  The PRO help topic is here the content is similar for ArcMap, but the dialog that appears for each tool will look different, but they contain the same functionality.
HishamAlghamdi1
Thanks for the help.
I still could NOT get the option to select SURFACE MODEL as shown in the video at 29 second (Calculate Solar Radiation - YouTube )
Please see all of the options of solar radiation in ArcGIS Pro in this image:
Solar Radiation Options in ArcGIS Pro
by any chance, was there materials to download and use... that is listed as a 'Task' which I suspect came with 'something' that I don't have here.
Jayanta_Poddar
Honored Contributor
HishamAlghamdi1
Sorry I could not find anything relate to what I am looking for jayanta.poddar
Is there any suggestion please!
Jayanta_Poddar
Honored Contributor
Did you download and configure the "Calculate Solar Radiation" configuration?
The tools you mentioned do not come in-built with ArcGIS Desktop (ArcMap/Pro).
They need to be downloaded from the link I mentioned above. It consists of a toolbox,viz., "AssessSolarRadiation.tbx".
This toolbox needs to be configured to ArcGIS Pro. This toolbox will contain the desired tools you mentioned.
Get started overview - Calculate Solar Radiation | ArcGIS for Local Government
Let me know if the desired tools are not available in the given toolbox. I am unable to test it since I don't have access to ArcGIS Pro now.
HishamAlghamdi1
Dear Jayanta Poddar
Can you please explain to me what is the purpose from Surface Model in the first task in the link that you provided to me?
I read but I couldn't get it properly.
Appreciate your help.
HishamAlghamdi1
Dear Jayanta Poddar‌
Thank you very much.
Now it makes sense to me as I am a know person to this program
Certainly I will do it and let you know if there is any issue.
Thanks!
