Using Callout Labels in ArcGIS
19006
06-29-2017 12:19 AM
JosephKerski
Esri Alum
1 4 19K
The ArcMap application within ArcGIS allows you to create an amazing variety of fonts, colors, and types of labels that identify point, line, and area features. One of the most useful types of labels is the callout label. This label “calls out” from the label to an off-site location that is typically not on the feature itself, and sometimes helps make maps that are more clearly understood by students. Consider the following example for a lesson I created about the Philippines. Here, if the labels were placed on the islands, they would obscure the data I wanted the students to explore, which was the human development index by administrative area (province). Therefore, I used callout labels so that they would be offset in the ocean.
How did I create these labels? Under the Layer Properties, under Labels, I selected a “Banner” style label. Under Properties for the banner style, I selected Properties once again, and then bumped up the x offset to 45 and the y offset to 30. You will have to experiment with your own data set for the optimal offset, depending on your map units and the feature shapes that you wish to label. I set the colors for the background and for the text.
I did something else to create the above labels. Many provinces are split up into hundreds of islands. To prevent every single island from receiving a label, I accessed the Placement Properties tool under the Label tab in the Layer Properties. Under Duplicate Labels, I indicated that I wanted only one label per feature:
You can also use the label tool in the draw toolbar to create interactive text labels as callout boxes, as shown below:
After remembering sticking sticky-back callout labels on maps way back in cartography’s manual days with an Xacto knife, these ArcGIS tools show the progress that has been made over the past 25 years!
I invite you to explore label placement to help the maps do what they are designed to do—to communicate!
Joseph Kerski, ESRI Education Manager
4 Comments
DakeHenderson
Callouts are a wonderful thing!  There's one unfortunate problem with these however. When the text box is positioned so the long side of the text box is orthogonal to the pointer's end point, the pointer becomes very wide and obscures the map contents. My feeling is that the width of the pointer where it intersects the box should always be the same. Most of the time the problem is avoidable, but sometimes not.  Is there a way to control the pointer's width?
Thanks
MeganScheeline
New Explorer
You can change the thick leaders to straight lines by going here:
Label styles > properties > symbol properties > edit symbol > advanced text tab > text background properties.
Then in the "Type" dropdown change it to Line Callout (retains the box around your text) or Simple Line Callout (does not retain the box). You can modify some of the properties from there to fine-tune the style.
StuSmith1
Which version of Arc Desktop?
How did you navigate to the ..."Banner style label"?
Your method forces all labels to move the same x and y offset.  What if I want to manually move each individual label to a different location?
ThachTran
Observer
Does anyone know if there is a way to assign these callouts to a specific layer or group that you can turn on and off?
About the Author
I believe that spatial thinking can transform education and society through the application of Geographic Information Systems for instruction, research, administration, and policy. I hold 3 degrees in Geography, have served at NOAA, the US Census Bureau, and USGS as a cartographer and geographer, and teach a variety of F2F (Face to Face) (including T3G) and online courses. I have authored a variety of books and textbooks about the environment, STEM, GIS, and education. These include "Interpreting Our World", "Essentials of the Environment", "Tribal GIS", "The GIS Guide to Public Domain Data", "International Perspectives on Teaching and Learning with GIS In Secondary Education", "Spatial Mathematics" and others. I write for 2 blogs, 2 monthly podcasts, and a variety of journals, and have created over 6,500 videos on my Our Earth YouTube channel. Yet, as time passes, the more I realize my own limitations and that this is a lifelong learning endeavor: Thus I actively seek mentors and collaborators.
