Why does IFieldChecker change the name of OID field?
139
04-26-2019 02:04 PM
WilliamWalker3
New Contributor III
The documentation for IFieldChecker states that the interface checks for errors in field names.  Specifically, it renames the OID field to "ObjectID" based on 4 cases.  When creating a standalone table in a geodatabase, using the IFieldsEdit interface to create the OID field, there are no requirements on what constitutes a valid name for the OID field.  However, if the OID field is not named "ObjectID" when fed to the FieldChecker, it is changed to "ObjectID".  What constitutes a valid OID field name?  Are there any restrictions on valid OID field names in a geodatabase?  Will naming my OID field something other than "ObjectID" cause issues?  See relevant code below:
    IFields fields = new FieldsClass();
    IFieldsEdit fieldsEdit = (IFieldsEdit)fields;
    fieldsEdit.FieldCount_2 = 10;
    IField field = new Field();
    IFieldEdit fieldEdit = (IFieldEdit)field;
    fieldEdit.Name_2 = "MyOidFieldName";
    fieldEdit.Type_2 = esriFieldType.esriFieldTypeOID;
    fieldsEdit.set_Field(0, field);
    // Add other fields here...
    // use IFieldChecker to create validated fields collection
    IFieldChecker fieldChecker = new FieldChecker();
    IEnumFieldError enumFieldError = null;
    IFields validatedFields = null;
    fieldChecker.ValidateWorkspace = (IWorkspace)fws;  //fws = my feature workspace
    fieldChecker.Validate(fields, out enumFieldError, out validatedFields);    //<--my OID field name is changed to "ObjectID"
arcobjects 10.4.1‌objectid‌fieldname‌
