ST_TRANSFORM: ORA-20603: Spatial References are not compatible
3043
09-07-2016 11:03 AM
WileyOsborn
Hi GIS USers,
I am attempting to transform a point:
To: NAD_1983_StatePlane_California_III_FIPS_0403_Feet (SRID 2227).
My workflow is that the user identifies create a point in 4326. This point is then transformed to 2227 to use in a SQL spatial query against other 2227 projected data.
So I use the SQL below and get "ORA-20603: Spatial References are not compatible." Well... I can definitely transform in ArcGIS Desktop between the two systems so.. yeah they can be made compatible.
I used KWID 108190 as the transformation NAD_1984_(ITRF00)_To_NAD_1983. I have also tried without a transform. In which table are the transform ID's listed?
What am I doing wrong here or this a bug?
BTW, I have setup PEDATAHOME and this is an Oracle 11g geodatabase that has ST_GEOMETRY enabled and configured.
select sde.ST_astext (sde.st_transform (sde.st_pointfromtext ('point (37.988675 -122.086967)', 0), 2227, 108190))
from dual;
Wiley
Contra Costa County
Public Works Dept.
George_Thompson
Esri Frequent Contributor
Hi Wiley,
You may want to contact https://community.esri.com/groups/technical-support?sr=search&searchId=97f6daab-0f69-4887-a0de-07a03...‌ and open a case with the geodata team to review that error. There could be a couple of different reasons.
I am also adding the https://community.esri.com/groups/geodatabase?sr=search&searchId=0da17ccb-ba2d-4048-8194-a780c69ff54...‌ group to see if anyone can chime in.
--- George T.
WileyOsborn
HI All,
My code was good I just had the Long and Lat reversed. I got the values from Google who uses LONG,LAT (aka Y,X). ESRI and ST_GEOMETRY uses LAT,LONG (aka X,Y).
select sde.ST_astext (sde.st_transform (sde.st_pointfromtext ('point (-122.086967 37.988675 )', 0), 2227, 108190))
from dual;
Works just fine.
