Select By Location
74
11-13-2020 10:07 AM
I have a question about the ARE_IDENTICAL_TO parameter for the Select By location Tool. If using this tool to select a line that is identical, does digitized direction matter? In other words, would two lines with the exact same vertices be considered identical if the order of their vertices was reversed?
Reply
I just did a quick check, and it appears ARE_IDENTICAL_TO means just that, identical.  I think the logic is that two lines with the same vertices but in different order are equivalent to each other but not identical to each other.
