Making request synchronous
3550
9
02-24-2017 08:22 AM
roshnibasu
New Contributor III
Is there a way to make the esri/request synchronous?
esriRequest(url, {
responseType: "json",
callbackParamName: "callback"
}).then(function(response){
console.log(resp);
FlavieMORAUX1
Hy roshni basu,
I ask myslef the same question. Have you found a way to do that?
Regards,
Flavie
roshnibasu
New Contributor III
Hi Flavie,
I had resolved this issue by making an API at my java code. And then call that API from my javascript making call synchronous.
Regards
Roshni
FlavieMORAUX1
Hi Roshni,
I found another solution, I request myself with dojo class "request/xhr".
Regards,
Flavie
var layerInfo = null;
var requestURL = layerUrl + "?f=json";
requestXHR(requestURL, {
   handleAs: "json",
   sync: true,
   headers: {
      "X-Requested-With": null
}).then(function(data){
   layerInfo = data;
return layerInfo;
AndresCastillo
MVP Regular Contributor
Although I see you have the dojo class "request/xhr" property of  sync set to a boolean value of true, then object still has a .then method promise.
Can you help me understand how this is synchronous please?
LeoLiu1
Hi Andres,
Check the doc for dojo/request/xhr here:
dojo/request/xhr — The Dojo Toolkit - Reference Guide
AndresCastillo
Thank you Leo.
I understand that the requestXHR function is set to sync.
But after it runs, it returns a promise, which would make it async again, right?
LeoLiu1
Hi Andres,
dojo/request/xhr uses XMLHttpRequest.open to perform the request. If 'sync' is true, the promise won't be returned until the request has completed.
AndresCastillo
Thank you Leo for your replies.
I will have to do a small test on different scenarios of this to see its' effect on the application's behavior.
MeghanKulkarni
New Contributor III
Thanks worked like a charm.
Meghan Kulkarni
