Issue in Finding routes between locations in xamarin
960
07-01-2016 04:35 AM
MobleJoseph
Hi All,
    I am facing issue with finding routes between two location in ARCGIS xamarin. I have tried the example https://developers.arcgis.com/xamarin/quartz/android/guide/find-a-route.htm . But in the example the URI used is  http://sampleserver6.arcgisonline.com/arcgis/rest/services/NetworkAnalysis/SanDiego/NAServer/Route
But i need to access the URI http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World  which requires authenticated call.So i registered my App by referring the link :Implementing App Login | ArcGIS for Developers. and generated the Token  and tried :"http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World/solve?token=<Token>&st... in Postman and is working fine, but not working in my App.
In the example the route task is fetched as follows:
    var routeSourceUri= new Uri("http://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World ");
    var routeTask = await RouteTask.CreateAsync(routeSourceUri);
I tried appending the uri with token, but it is not working.
Can anyone suggest a workaround to get the routeTask in xamarin with token authentication.
Thanks in advance.
