Is it possible to design a web based Multicriteria Analysis Application using Arcpy?
672
01-19-2018 09:16 PM
FarhanMustafa
I am working on suggesting the potential sites for industries in a province.The process includes 18 layers. I am done with the MCDA results and maps. Now I want to design a web based application in which I can change the criteria (weights of different indicators) and can get the result as a map on web page. Is it possible using ArcGIS or any other way?
Regards
XanderBakker
Esri Esteemed Contributor
Yes you can! In the Web AppBuilder you can configure the Suitability Modeler widget—Web AppBuilder for ArcGIS | ArcGIS to use your own data. In Github there is a explanation of how you can do this: GitHub - Esri/weighted-raster-overlay-service-toolbox: Tools to help you setup a mosaic dataset to s...
XanderBakker
Some additional info can be found in this blog: GeoPlanner for ArcGIS: Weighted Raster Overlay Service Toolbox | ArcGIS Blog
