HTML Popup : How to add a link to a local .pdf
4387
02-07-2017 01:13 PM
BuffaloCoWI
How does one go about creating links to locally stored .pdf documents using the HTML Popup XSL templates?
We have thousands of .pdf's stored locally and we would like to reference the .pdfs as links when selecting features.
Some features would need multiple reference.pdfs links.
In the attribute table I've got a field populated with paths look like this:  p:/Zoning/drawings/40.pdf
I've tried inserting " p:/ " into the XSL with no luck.
What's the trick?
Links in HTML Pop-ups
Tags (3)
BuffaloCoWI
Located a working solution
ArcGIS Explorer Desktop Layers & Hyperlink
The link or url attribute field needs to be formatted like:
file:///C:/Users/testfolder/documents/test2.pdf
In the XSL default HTML Popup template the key was the line below:
<xsl:when test="FieldValue[starts-with(., 'file')]">
mbockenhauer, provided a nice example of how it worked.
http://www.arcgis.com/home/item.html?id=81b39307fde04dd99656f3e19e4e0715
