How to use "geometryEngine" in arcGIS Version 3.9
1914
04-15-2016 03:16 AM
Muhammad_TahirShah
We are using arcGIS version 3.9 in our portal. Now we have new requirement to do reverse clipping on map. We have already written code to implement reverse clipping with the help of "esri/geometry/geometryEngine". The issue is that "esri/geometry/geometryEngine" was introduced in 3.13 and we are using 3.9 in our portal.
When we try to load
require(["esri/geometry/geometryEngine"], function(geometryEngine) { /* code goes here */ });
in version 3.9,  it gives error.
Is there any way to use "esri/geometry/geometryEngine" in version 3.9?
