How to change the expiration time of the token generated in application developed using Web App Builder
348
02-05-2018 03:03 AM
New Contributor II
I have developed an app using Web App Builder developer Edition and I am trying to change the expiration time of the token in tokenUtils.js file as below
 var oAuthInfo = esriNS.id.findOAuthInfo(portalUrl);
      if(!oAuthInfo){
        var oauthReturnUrl = window.location.protocol + "//" + window.location.host +
         require.toUrl("jimu") + "/oauth-callback.html";
        //OAuth will lose 'persist' query parameter if set expiration to two weeks exectly.
        oAuthInfo = new OAuthInfo({
          appId: appId,
          //expiration: 14 * 24 * 60 - 1,
          expiration: 2,
          portalUrl: portalUrl,
          authNamespace: '/',
          popup: true,
          popupCallbackUrl: oauthReturnUrl
        esriNS.id.registerOAuthInfos([oAuthInfo]);
 But while checking the response of generated token request in network tab, I am getting the token value and expiration time as below
{"token":"asdfghjk","expires":1518432766610,"ssl":false}
 Hence the token is not getting expired in 2 mins as desired.
Reply
New Contributor II
Mayur Patel‌ Good morning. Did you find a solution to this problem? I need to do something similar.
Thank you
Reply
New Contributor II
Mayur Patel‌ I just tested your solution and it works fine: my application asks to log back in and a new token is generated. Thanks!
Reply
