How can I load field values into an array using arcade expression?
1597
11-10-2017 02:28 PM
EricPeña
I am exploring Add Attribute Rule in ArcGIS Pro 2.1-beta.1.  I want to look at all values in an ID field, take the max value, and add 1. This way I can set up a rule that will always add the sequential number on INSERT.  How can I create an array of all existing values in an ID field? Is this possible with an arcade expression?
DanielWebb
Has this been answered anywhere?  I'm new to Arcade expressions.  Thanks!
JoeBorgione
Take a look at Create Database Sequence—Data Management toolbox | Documentation .  Sequences do the dirty work for you at the database level, all you do is create a simple attribute rule to use them at the feature class level.
That should just about do it....
OrrGvili
New Contributor III
this workd for me
var features = FeatureSetByName($datastore,"polygons",["ID"],true)
var NewID = Max(features,"ID")+1
return NewID
