How can fix the issue for mbtiles?
442
10-06-2017 08:33 AM
jinyingmin
Hello, everyone,
I have been developing offline map application using ArcGIS Android SDK 10.2.9
I used mbtiles. But there is one issue. I know I can use mbtiles using ArcGIS Android SDK, but my mbtiles does not display on the map.
I have another sample mbtiles, it displayed on the map.
I checked both in spatialite, I have seen these table schema are different each other.
I don't understand about that.
Who can help me?
How can display my mbtiles on the map?
I attached the mbtiles on this page.
Thank you.
AhmetEmre
New Contributor III
Hello  jin yingmin ,
Same problem here
Have you reached to a solution ?
jinyingmin2
Nice to meet you, Ahmet Emre.
Eventually, I have found the reason why not displayed the mbtiles on the map
Because the ArcGIS Android SDK not allows to use mbtiles for small area
I think it is ESRI SDK issue
I hope eagerly they would solve this issue.
So after this, I used mapsfoge SDK for offline map
It does works as well.
We can discuss more details.
AhmetEmre
New Contributor III
Thank you Jin..
by the way my email is mirliva1976@gmail.com
