GetOleDbSchemaTable Fails With FileGeoDatabase
1798
01-05-2016 09:20 AM
I'm trying to extend some existing code to support FGDB connections, but I'm getting an unhelpful error when I try to make calls using my connection. I have an open connection and am trying to call GetOleDbSchemaTable in a try/catch. The application runs as an ArcMap extension and this portion of the code runs after everything has loaded.
Connection String: "Provider=ESRI.GeoDB.OleDB.1; DATA SOURCE = C:\Projects\Demo\Workspaces\FGDB.gdb; Extended Properties=workspacetype=esriDataSourcesGDB.FileGDBWorkspaceFactory.1; Geometry=WKB"
DataTable table = cnn.GetOleDbSchemaTable(System.Data.OleDb.OleDbSchemaGuid.Columns, new object[] { null, null, tableName, null });
Could not retrieve schema information for table tableName due to an error: 'ESRI.GeoDB.OleDB.1' failed with no error message available, result code: DB_E_NOTSUPPORTED(0x80040E53).
I was using this older forum post as a reference Importing data from a File GeoDatabase
It seems like you can select on the OleDbSchemaGuid.Tables, but not the OleDbSchemaGuild.Columns. Is this unsupported?
Reply
We continue to battle with the ESRI.GeoDB.OleDB.1 provider. The documentation is severely lacking, and the functionality seems equally lacking, from my experience thus far.
Reply
