ExportTileCacheJob never starts
1435
02-15-2017 12:12 PM
CalebPourchot
I'm using the .Net runtime sdk (v.100) for Xamarin Android. I'm trying to download tiles as a .tpk for offline use by my mobile app.
I've managed to use the AuthenticationManager to give me a token for my app. I can successfully create the ExportTileCacheTask and create the ExportTileCacheJob by calling ExportTileCache on the ExportTileCacheTask, but the status of the job never seems to change. When I check the job status immediately after the call to ExportTileCache, it is "NotStarted" and the ServerId = "". I have a breakpoint on my ExportJob_JobChanged handler and it never gets hit no matter how long I wait.
Any ideas? Code below:
var serviceUri = new Uri("https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Imagery/MapServer");
var tokenUri = new Uri("https://www.arcgis.com/sharing/rest");
try
var serverInfo = new ServerInfo
ServerUri = tokenUri,
TokenAuthenticationType = TokenAuthenticationType.OAuthClientCredentials,
OAuthClientInfo = new OAuthClientInfo { ClientId = MYCLIENTID, ClientSecret = MYCLIENTSECRET) },
AuthenticationManager.Current.RegisterServer(serverInfo);
var cred = await AuthenticationManager.Current.GenerateCredentialAsync(tokenUri, new GenerateTokenOptions { });
var exportTask = await ExportTileCacheTask.CreateAsync(serviceUri, cred);
var exportParams = await exportTask.CreateDefaultExportTileCacheParametersAsync(aoi, 50000, 10000);
job = exportTask.ExportTileCache(exportParams, localFilePath);
job.JobChanged += ExportJob_JobChanged;
catch (Exception e)
e.ToString();
CalebPourchot
Apparently the tooltip documentation on ExportTileCache is misleading. It does not, in fact, Start and return an ExportTileCacheJob. You must call Start() on the job to start it.
I finally found java documentation of the class that mentioned this.https://developers.arcgis.com/android/latest/api-reference/reference/com/esri/arcgisruntime/tasks/ti...
After calling Start(), the JobChanged events fired as expected and I was able to successfully download a .tpk file.
CalebPourchot
