Do calculation attribute rules apply when published to ArcGIS Online?
1439
04-25-2020 12:50 PM
by Anonymous User
Not applicable
I have a file geodatabase with layers containing an attribute rule that will calculate a field based on an intersection with another layer. The rule works on the file geodatabase layer in ArcGIS Pro, but when I publish the layers to ArcGIS Online, it stops working, and there are no attribute rules associated with the hosted feature layer. Any idea why it won't carry over? I suspect that I need to tweak the expression to reference $map rather than $datastore (maybe?!), but $map isn't recognized prior to the upload.
by Anonymous User
Not applicable
Do I need ArcGIS Enterprise in order for this to work?
DezsoLovicsek
New Contributor III
Am wondering the same thing....
BrackenDavis
New Contributor III
Tara Hunter‌, I'm having the same problem, were you ever able to get it to work?
XanderBakker
Esri Esteemed Contributor
Hi Tara Hunter , Dezso Lovicsek  and Bracken Davis ,
Unfortunately, Attribute Rules currently only work in File Geodatabases and Enterprise Geodatabases and are not yet supported in ArcGIS Online.
