Attribute Assistant how to run "GENERATE_ID_BY_INTERSECT" only when ID is empty
2802
06-29-2015 12:02 PM
JoseSanchez
Hello everyone,
Is there a way to populate the feature class ID using the rule "GENERATE_ID_BY_INTERSECT" only when field ID is empty in the feature class. The goal is to avoid to generate several times the a new ID for the same feature.
MikeMillerGIS
Esri Frequent Contributor
The Generate ID by Intersect does not support this option.  We have added this option to the Generate ID method.  I logged an enhancement to add this capability to the Generate ID by Intersect.
Enhancement - Generate ID by Interest · Issue #50 · Esri/local-government-desktop-addins · GitHub
