ArcGIS Online Labels with Arcade Custom Expression Won't Render in App
2557
01-19-2017 12:29 PM
MichaelSakinejad2
New Contributor II
I'm trying to label address points (with the ArcGIS Online labeling functionality) for one of our city's webmaps. Some of the addresses have unit numbers, some don't. I put together an Arcade expression that checks the "unit" field for values so that all points will be labeled correctly.
var unitVal = $feature.unit
var stVal = $feature.snumber
function mainfunc(unitVal,stVal){
  if (unitVal == ' '){
      return stVal
  else {
      return Concatenate([stVal,unitVal], ':')
mainfunc(unitVal,stVal);‍‍‍‍‍‍‍‍‍‍‍‍‍
The labels appear correctly in ArcGIS Online, but will not draw in a web application that calls on that AGO map. Has anyone come across the same issue?
Labels in ArcGIS Online Lack of Labels in Webmap
by Anonymous User
Not applicable
Michael,
     Have you tried adding semicolons at the end of your first two lines?
--- Rod
MichaelSakinejad2
New Contributor II
Hi Rod,
Just tried that, and no change, unfortunately.
Thanks for looking into it
KristianEkenes
I'm looking into this as well... will reply if I learn anything.
FYI, the expression could also be condensed to the following (but it doesn't really matter. Depends on your preference):
var unitVal = $feature.unit;
var stVal = $feature.snumber;
IIF(unitVal == ' ', stVal, Concatenate([stVal,unitVal], ':'));
KristianEkenes
Which version of the JS API are you using, 4.x or 3.x? Labeling isn't supported in 4.x yet. I was able to verify this in a 4.x app, but noticed the expected behavior in 3.x...
4.x test case: JS Bin - Collaborative JavaScript Debugging
3.x test case: JS Bin - Collaborative JavaScript Debugging
