how to change the layer order in LayerList ?
2070
05-11-2017 06:43 PM
ShaosongMa
I want to change the order of layers in my view,My JS  is V4.3 .
Tags (1)
FC_Basson
MVP Regular Contributor
The Map object has a reorder method with which you can specify the layer index: Map | API Reference | ArcGIS API for JavaScript 4.3
You can also specify the layer index when adding the layer.
ShaosongMa
Thanks for your help. That help me a lot!!!
AdrianWelsh
MVP Honored Contributor
If this solved your question, please mark FC Basson's answer as "Correct".
