It would be useful to add support to set values to Repeats (Repeats—Survey123 for ArcGIS | Documentation) with the JavaScript API (setQuestionValue method, constructor of WebForm, etc.). Also, support is also needed to set, add or remove records in Repeats.
Thank you!
