I would like to be able to copy a layer from one web map and transfer it to another, where symbology of the layer in the webmap is retained instead of the added layer using the symbology derived from the REST. It is able to grab everything else from the layer(pop-up configuration, filter, etc), but symbology does not work. Attached is my relevant code fragment.
