We just pushed out a new version of Esri-Leaflet and now its easier than ever to get familiar with the source code of the API.
Steps:
This application points at local source files that are organized in the same directory structure as the GitHub repository itself. This means that you can use the developer tools inside your browser to inspect the API source.
I’ve always found that setting breakpoints and stepping through the code slowly makes the logic that’s being employed to talk to ArcGIS Server and ArcGIS Online hosted content a lot easier to understand.
