Data reviewer regular expression not working
10073
20
10-12-2015 06:42 AM
NeilWrobel
Hi
I would like some help with the following:
I have a feature class with the field REF_ID. I would like to constrain what is entered by setting a regular expression for data reviewer to pick up any mismatches.
The REF_ID entries are a semi-colon delimited list of ids.
The REF_IDs can be anything from a single digit starting at '1' and can be up to a maximum of five digits.
The delimited list has no limit other than the character limit of the field.
Here are some examples:
12345                         OK
1234                           OK
123                             OK
12                               OK
1                                 OK
123456                       BAD
12345; 54321; 1234; 123                           OK
123456; 654321                                         BAD
12345;54321;                                             BAD
I have done the expression a few different ways and changed it because it seems that Data Reviewer doesn't like something.
I have checked all the expressions in Debuggex and all worked correctly, but just don't work in Data Reviewer.
I was getting all records being returned.
Here is the expression I ended up with which appears to work on records with a single REF_ID entry but not on a delimited list.
i.e. works on '12345' but not on '12345; 54321'
^([1-9](\d)?(\d)?(\d)?(\d)?)(;\s?([1-9](\d)?(\d)?(\d)?(\d)?))*$
Some help with this would be appreciated.
Thanks.
Neil
PythonData Quality ManagementData Reviewer
ChrisSmith7
Honored Contributor
Neil,
I believe this may work for you:
^((\d{1,5};*)(\d{1,5};\s*\d{1,5})*)$
I tried it for the following scenarios:
12345                         OK
1234                           OK
123                             OK
12                               OK
1                                 OK
123456                       BAD
123456; 654321                                         BAD
12345;54321;                                             BAD
ChrisSmith7
Honored Contributor
It's no good when it's just something like:
12345;
Trying to rework a bit...
NeilWrobel
But that's good because 12345; would be incorrect as i don't want a trailing semi-colon.
ChrisSmith7
Honored Contributor
A bit inelegant, but this should cover all bases:
(^\d{1,9}$)|(^((\d{1,9};\s*\d{1,9})(\d{1,9};\s*\d{1,9})*)$)
Here's how I tested:
Matched:
123
1234
12345
123;12345
123; 12345
123;12345;12345
123; 12345; 12345
123; 12345;12345
Not matched:
123456
12345;
123;123456
123; 12345; 12345;
NeilWrobel
Thanks Chris, but the solution you provided is the one we tried in the first place but it doesn't work.
I have had three very experienced developers look at this and they don't know why it won't work.
ChrisSmith7
Honored Contributor
You tried it with the updated suggestion?
It's a pretty standard regex - if it doesn't work, there may be something specific to Data Reviewers' implementation of regex that makes it special.
NeilWrobel
Yes. Tried the updated one and doesn't work.
Not great!!
There is nothing particularly complicated with the data.
NeilWrobel
Did you test it in Data Reviewer or a regex tester??
ChrisSmith7
Honored Contributor
Yeap - I used Regex Hero:
Online .NET Regular Expression Tester and Reference
It's geared towards the .net implementation of regex, but I didn't use anything too complicated - I've used similar expressions in Java in the past.
