XML Editor
1310
10-06-2017 09:04 AM
JoeBorgione
At my last job I downloaded an xml editor that worked really well to make changes to Feature Class attribute schemas. By exporting the "schema only" in arc catalog I got the xml file and open it in the editor.
The editor would display the xml as a series of folders which makes inserting a new field a snap.  I thought it was notepad ++ but I just downloaded it here at my new job and it's only displaying a traditional xml <tags> type of format.
Does anyone know which xml editor I'm describing here?
DanaNolan
X-ray for Geodatabases/ArcCatalog, perhaps? I can't get it to run on my security-limited system, but it has fans.
JoeBorgione
Thanks Dana- I too have struggled with x-ray, so I know it wasn't that.
Dana Nolan
eta moments later:  Microsoft XML Notepad.  available here:  Download XML Notepad 2007 from Official Microsoft Download Center
Here is a shot of an ArcGIS/ArcCatalog generated xml file of a table.  I need to add a few fields.  Lets say I needed to add a new field above the field called NAME.  I just insert a new folder where I want it, call it what I want it, define it like I want, save it, import it back into ArcGIS and I'm good to go....
Sizige
Joe,
I just saw this post and that is what I use to use as well.  It was so nice to tweek the geodatabase design.  However  the tool is not available any more from the microsoft page.  I have tried other XML editors, but they strip off the ESRI part, and it won't import.  Have you found one that works other than the XML notebook?
Regards
Allen Wright
by Anonymous User
Not applicable
Hey Joe hope you are well,
please could you kindly help me!
i try to import XML into SDE (SQL server) database but it failed and give me the following error:
"Underlying DBMS error [[Microsoft][ODBC Driver 17 for SQL Server][SQL Server]Violation of PRIMARY KEY constraint 'R42_pk'. Cannot insert duplicate key in object 'dbo.GISVW_SAFE_DISTANCE'. The duplicate key value is (1).] [texttXML.DBO.GISVW_SAFE_DISTANCE]"
Software: ArcGIS Pro2.6.2
