What is differences between arcsde 9.3 and arcsde 10.0
4150
09-23-2014 01:00 AM
SalihYalcin
New Contributor III
Hello everyone,
I am curious that what is differences between arcsde 9.3 and arcsde 10 ? Is there ArcSDE 10 to use it ? Or ArcSDE 10 is coming with  ArcGIS for Servers ?
Can anyone explain me ?
Thanks in replies.
Tags (1)
VinceAngelo
Esri Esteemed Contributor
If you're going to post the same question both here and on GIS.stackexchange, please mention this in your posting.
Another similar answer exists at GSE.
- V
AsrujitSengupta
Regular Contributor III
Can you explain what differences are you exactly looking for? As in, differences in terms of the setup, licensing, Structure of the sde geodatabase, functionalities, etc...
Starting from 10.1, installation of ArcSDE is optional. You only need to install it if you want to use the SDE Command line tools or the SDE Application Server (SDE Service) connection.
Also please note that the SDE Command line tools or the SDE Application Server (SDE Service) connection are planned for deprecation in the next major release (10.3).
AsrujitSengupta
VinceAngelo
- V
SalihYalcin
New Contributor III
I mentioned on my question Thank you for reminding.
JohnBaleja
New Contributor II
Here is a link on what is new in ArcGIS 10 for geodatabases:
ArcGIS Desktop
Here is a top level description of what's new in ArcGIS 10:
ArcGIS Desktop
John Baleja
Product Manager - Database Technology
