Unpivoting multi-value answers to a Survey 123 question
1479
07-08-2021 05:35 PM
AlfredBaldenweck
MVP Regular Contributor
I'm looking at doing data entry connecting documents to land parcels.
Each document can apply to multiple parcels.
I would like to create a survey (for ease of data entry) and use a multivalue question associate the two, then unpivot it so I have a table to relate my list of documents and my list of parcels.
E.g.
Becomes
Is there an easy way to unpivot data?
If there is, can I set it up to happen automatically with each form that comes in? I understand that would probably end up making two different tables (Raw and Final), but I'm fine with that.
I also understand that Survey 123 is not necessarily the best program for this; if anyone has any suggestions for this, I'd happily take them. I know that you can unpivot in MS Access, for example. The goal is to be contributing to the table as new documents are created with minimal data entry instances.
Thanks!
jcarlson
MVP Esteemed Contributor
Have you considered using a related table for this? In Survey123, they're referred to as Repeats. (https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformrepeats.htm)
That way your documents only get entered once, and each can relate to as many parcels in your related table as necessary. Graphically, that would look like:
Main Table
OIDBookAuthor
1War and PeaceTolstoy
2My Life and Hard TimesThurber
Related Parcels
OIDRel_IDParcel
11St. Petersburg
21Stalingrad
32Columbus, OH
If you needed to recombine the tables into the second picture in your post, this can easily be done by means of an attribute-based join.
- Josh Carlson
Kendall County GIS
jcarlson
Main Table
OIDBookAuthor
Related Parcels
OIDRel_IDParcel
11St. Petersburg
21Stalingrad
32Columbus, OH
- Josh Carlson
Kendall County GIS
AlfredBaldenweck
I think this will work great!
Thank you!
AlfredBaldenweck
Sorry, just tested it and have two questions.
It looks like it relates off of Global ID; is it possible to set it up using a different key? Or should I just add in another question and domain/data validate to ensure that the correct ID is also assigned?
jcarlson
As far as I know, Survey123 requires globalID values to relate to one table to another, even though you can establish a relate of your own based on other fields. The globalID / GUID values would all be managed automatically, so it wouldn't be too difficult to manage for new features.
If you add another question, it's going to assume that's a field in the parent table. Going that way, you either need to enter your data in the "unpivoted" style (one submission per author-parcel combo), or else you'll end up with multiple columns for additional parcels.
- Josh Carlson
Kendall County GIS
