How do you delete points that were added using a locator or the Find-> Locations input? I added several points to the map with the context menu in the Find pop-up, but I don't know how to delete them.
You can also select all the the graphical element such as graphical points, lines text using the menu command Edit>Select All Elements. Then you can delete them all at once. There is a toolbar command in the Draw Toolbar.
