unable to see the Geo coding processed data in Arc MAP
405
07-20-2011 05:42 AM
jagadeeshrao
Hello everyone
I need to geocode a table of City addresses layer in USA. Initial i have created Address locator using Arctool box. it was sucessfully created and its saved as below extension.
cities_CreateAddressLocator1
cities_CreateAddressLocator1.loc.xml
cities_CreateAddressLocator1.lox
Next Process:
When I went to Arc MAP using Geo coding tool> Geocode Addresses, chose the added address locator and  selected my address table Export_Output.dbf with the city addresses and choosen the required fields. The geo coding process is sucessfully completed. But we are unable to see any data in Arc MAP but we can see table information for city layer. See the snap shot.
Anyone can suggest how i can see data after geo coding process. Is there any wrong of my above process.
Thank you
Jagadeesh
JoeBorgione
From your snapshot, none of your records are matched; look at the Status column.  "U" = unmatched.  Look at the score column: 0 means it didn't even partially match.
Without knowing what kind of locator you used, the data it is based upon, as well as how your address data is formatted, it's impossible to assess where the problem(s) lie.
