The use of <> whilst setting up a definition query
4846
12
07-16-2014 06:40 AM
PatrickMurphy1
Over the last couple of years I've been using the <> in query builder to exclude out certain categories, unfortunately this year it doesn't seem to be working anymore.
I am using the same data, the same version of ArcMap (10.0 Service Pack 5).
Would be any obvious reason for this
Paddy
Tags (1)
PatrickMurphy1
Hi to All
It has finally worked out for me
I just replaced the "OR" with "AND" and it worked
Thanks all
Appreciate it
Regards
Paddy
DanPatterson_Retired
Not sure.... often != is used to represent not equal to
PatrickMurphy1
Hi Dan
I tried that and it didn't work, when i verify its telling me "The expression was successfully verified"
Thanks anyway
Paddy
PatrickMurphy1
Hi Sol
The data is from an SDE server. It is a String field, Unfortunately I don't have access to the SQL databse.
Cheers
Paddy
PatrickMurphy1
Hi again Sol,
I tried that and the same result, All records were selected
Paddy
PatrickMurphy1
=, came up with an error when I verified it.
I'm using the options from "Get unique Values" so case sensitivity doesn't apply.
It might be a matter of doing the Query the long way
Thanks
Paddy
PatrickMurphy1
This is how my query is set up, the intention of this is to show all categories except "Complete" and "Expired"
Also this is the Error I received when using the =,
RyanStovern__GISP
Change your "Or" to an "And" and see what happens. This should give what you want. By using "And" you are telling the query you want all attributes that are not Complete or Expired.By saying "Or" it is confused on which ones to exclude.
ScottDean
Make sure it is setup like the following.
[field name]  + operator + value and [field name]  + operator + value
Example
STATUS <> 'COMPLETED' AND STATUS <> 'EXPIRED'
Obviously I do not know what your field is called so that needs to be changed in the example.
try putting either side of your OR or AND expression in round brackets ie ( )  Also, I assume that you are selecting rather than typing while you build the expression
