I suspect the problem is brought out by oracle bug, there is an article in oracle, ã??Ora-
13236Internal Error In R-Tree Processing During Heavy DML [ID 443422.1]ã??.I modify attribute
parameter, upgrade linux 10.2 to latest version according to solutions in the articleï¼? but the
error still exsits.
Then I detect bad block all data files in oracle, and don't find abnormal phenomenon.
Then I trace this error of ArcMap, the .trc file as follows:
PARSING IN CURSOR #137 len=80 dep=2 uid=78 oct=3 lid=78 tim=1267332140230147 hv=1378123736
ad='8fcbe930'
SELECT info from "USER_20101015".MDRT_19FCD$ where rowid = :rid for update
END OF STMT
PARSE #137:c=0,e=119,p=0,cr=0,cu=0,mis=1,r=0,dep=2,og=1,tim=1267332140230143
EXEC #137:c=0,e=354,p=0,cr=1,cu=0,mis=1,r=0,dep=2,og=1,tim=1267332140230560
FETCH #137:c=0,e=4,p=0,cr=0,cu=0,mis=0,r=0,dep=2,og=1,tim=1267332140230587
EXEC #139:c=192012,e=180481,p=0,cr=224,cu=1,mis=0,r=0,dep=1,og=1,tim=1267332140230708
ERROR #139:err=13236 tim=2044901203
WAIT #0: nam='db file sequential read' ela= 10296 file#=102 block#=17161 blocks=1 obj#=-1
tim=1267332140245801
WAIT #0: nam='db file sequential read' ela= 25 file#=29 block#=131697 blocks=1 obj#=-1
tim=1267332140249836
WAIT #0: nam='SQL*Net message to client' ela= 3 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332140259189
*** 2011-02-15 13:35:57.100
WAIT #0: nam='SQL*Net message from client' ela= 44408699 driver id=1650815232 #bytes=1 p3=0
obj#=-1 tim=1267332184667958
EXEC #28:c=0,e=248,p=0,cr=7,cu=3,mis=0,r=1,dep=1,og=1,tim=1267332184668389
XCTEND rlbk=0, rd_only=0
EXEC #41:c=0,e=244,p=0,cr=0,cu=1,mis=0,r=0,dep=1,og=0,tim=1267332184668696
WAIT #40: nam='SQL*Net message to client' ela= 3 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184668963
EXEC #40:c=0,e=945,p=0,cr=7,cu=4,mis=0,r=1,dep=0,og=1,tim=1267332184668993
WAIT #40: nam='SQL*Net message from client' ela= 354 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184669402
EXEC #19:c=0,e=20,p=0,cr=0,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184669468
FETCH #19:c=0,e=11,p=0,cr=2,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184669509
WAIT #19: nam='SQL*Net message to client' ela= 2 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184669551
WAIT #19: nam='SQL*Net message from client' ela= 70 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184669649
EXEC #25:c=4001,e=17,p=0,cr=0,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184669708
WAIT #25: nam='SQL*Net message to client' ela= 2 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184669776
FETCH #25:c=0,e=46,p=0,cr=3,cu=0,mis=0,r=1,dep=0,og=1,tim=1267332184669799
WAIT #25: nam='SQL*Net message from client' ela= 225 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184670066
PARSING IN CURSOR #136 len=138 dep=0 uid=78 oct=3 lid=78 tim=1267332184670429 hv=3971663499
ad='8e917e28'
SELECT /* ESRI GDM_4 */ state_id,owner,creation_time,closing_time,lineage_name,parent_state_id
FROM SDE.states WHERE parent_state_id = :id
END OF STMT
PARSE #136:c=0,e=305,p=0,cr=0,cu=0,mis=1,r=0,dep=0,og=1,tim=1267332184670423
EXEC #136:c=0,e=931,p=0,cr=0,cu=0,mis=1,r=0,dep=0,og=1,tim=1267332184671444
WAIT #136: nam='SQL*Net message to client' ela= 2 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184671492
FETCH #136:c=0,e=29,p=0,cr=2,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184671557
WAIT #136: nam='SQL*Net message from client' ela= 126 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184671747
EXEC #60:c=0,e=39,p=0,cr=0,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184671830
FETCH #60:c=0,e=83,p=0,cr=10,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184671942
WAIT #60: nam='SQL*Net message to client' ela= 2 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184672018
WAIT #60: nam='SQL*Net message from client' ela= 60 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184672106
EXEC #9:c=0,e=21,p=0,cr=0,cu=0,mis=0,r=0,dep=0,og=1,tim=1267332184672168
WAIT #9: nam='SQL*Net message to client' ela= 2 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184672224
FETCH #9:c=0,e=49,p=0,cr=2,cu=0,mis=0,r=1,dep=0,og=1,tim=1267332184672246
WAIT #9: nam='SQL*Net message from client' ela= 193 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184672482
EXEC #61:c=0,e=141,p=0,cr=3,cu=0,mis=0,r=0,dep=0,og=2,tim=1267332184672699
FETCH #61:c=0,e=69,p=0,cr=2,cu=0,mis=0,r=0,dep=0,og=2,tim=1267332184672802
WAIT #61: nam='SQL*Net message to client' ela= 2 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184672869
WAIT #61: nam='SQL*Net message from client' ela= 77 driver id=1650815232 #bytes=1 p3=0 obj#=-1
tim=1267332184672978
Get infomation:
SELECT info from "USER_20101015".MDRT_19FCD$ where rowid = :rid for update, this sql result in
error.
This is DDL of USER_20101015".MDRT_19FCD$ table:
CREATE TABLE "USER_20101015"."MDRT_19FCD$"
"NODE_ID" NUMBER,
"NODE_LEVEL" NUMBER,
"INFO" BLOB
PCTFREE 2 PCTUSED 40 INITRANS 1 MAXTRANS 255 NOCOMPRESS NOLOGGING STORAGE
INITIAL 65536 NEXT 1048576 MINEXTENTS 1 MAXEXTENTS 2147483645 PCTINCREASE 0 FREELISTS 1
FREELIST GROUPS 1 BUFFER_POOL DEFAULT
TABLESPACE "TBS_USER_20101015" LOB
"INFO"
STORE AS
TABLESPACE "TBS_USER_20101015" ENABLE STORAGE IN ROW CHUNK 8192 PCTVERSION 10 CACHE
STORAGE(INITIAL 65536 NEXT 1048576 MINEXTENTS 1 MAXEXTENTS 2147483645 PCTINCREASE 0 FREELISTS 1
FREELIST GROUPS 1 BUFFER_POOL DEFAULT)
MONITORING ENABLE ROW MOVEMENT ;
CREATE UNIQUE INDEX "USER_20101015"."SYS_IL0000106446C00003$$" ON
PCTFREE 10 INITRANS 2 MAXTRANS 255 STORAGE(INITIAL 65536 NEXT 1048576 MINEXTENTS 1
MAXEXTENTS 2147483645 PCTINCREASE 0 FREELISTS 1 FREELIST GROUPS 1 BUFFER_POOL DEFAULT)
TABLESPACE "TBS_USER_20101015" PARALLEL (DEGREE 0 INSTANCES 0) ;
I analyse structure of index "USER_20101015"."SYS_IL0000106446C00003$$",don't find
Then I locate primary table,
1.
select sdo_index_owner,sdo_index_type,sdo_index_table,sdo_index_name
from all_sdo_index_metadata
where sdo_index_table='MDRT_19FCD$' and sdo_index_owner='USER_20101015'
SDO_INDEX_OWNER SDO_INDEX_TYPE SDO_INDEX_TABLE
SDO_INDEX_NAME
USER_20101015 RTREE MDRT_19FCD$
A446_IX1_A
2.
select owner,index_name,index_type,table_name from all_indexes where index_name='A446_IX1_A'
OWNER INDEX_NAME INDEX_TYPE
TABLE_NAME
USER_20101015 A446_IX1_A DOMAIN A3921
3.
select registration_id,table_name,owner from SDE.table_registry where registration_id='3921'
REGISTRATION_ID TABLE_NAME OWNER
3921 LOG_OPERATE_FEATURE USER_20101015
The table which result in error isï¼?LOG_OPERATE_FEATURE
Then I rebuid the spatial index of LOG_OPERATE_FEATURE, reuse ArcMap, the error don't appearã??
Is this error oralce bug? Does this error happen by accident?
