Subtype or New featureclass for better performance
4467
6
12-29-2014 05:08 AM
SreejaS
We have a scenario that New data has to be uploaded in the database and presented in multiple applications - desktop, web and mobile.
My question is there are 2 options to upload this data
1. As a subtype to existing featureclass and present as part of the existing layer.
2. As a new featureclass and present as a new feature layer.
Which of the above options is better with respect to performance (map loading, navigation, spatial querying)?
Thanks in Advance
Sresree
TimWitt2
MVP Alum
Sreeja,
since it is such a vast amount of features, I would create new feature classes.
Tim
TimWitt2
MVP Alum
Hey Sreeja,
How many features would this particular data have? How many features would the feature service have that you would in cooperate the new data?
I think it really depends on the quantity and size of the feature services, that you would be using.
Tim
SreejaS
Hello Tim,
Thanks for the reply.
There are 2 layers - one point and another polygon.
The new points are around a lakh.
The existing points are in tens of lakhs.
The new polygons are in thousands.
The existing polygons are around tens of thousands.
Which approach would benefit performance of the overall application presenting new and existing data?
Regards
Sreeja.
TimWitt2
MVP Alum
Sreeja,
Tim
SreejaS
Hello Tim,
Thank you for the reply. But this data is part of a Geometric Network. The question we have is will it hamper the performance of the network if we add a new layer than a subtype to an existing featureclass?
Thanks & Regards
Sreeja S.
MarcelaRondon
Hello Sreeja, which option did you use and how was the performance of the network?
SreejaS
Not sure if I am too late in answering this. We opted a new feature class. Performance of geometric network has come down but the decision was not purely based on performance alone, but on several other criteria. A new layer in the network is expected to bring down performance. More details can be found at http://resources.arcgis.com/en/help/main/10.1/index.html#//002r00000004000000
ArcGIS Help 10.1
Thanks & Regards
Sreeja S.
