I am having a strange problem with an SQL query that I have used successfully in the past, namely:
SELECT * FROM TABLE WHERE:
[ELEVATION] IN (SELECT MAX( [ELEVATION] ) FROM TABLE GROUP BY [GRID_BOX] )
(I have binned many mountain peaks into a grid using the INTERSECT TOOL to give the GRID_BOX field.)
I run the query without any errors but the results are not at all as expected. Instead of returning a single point per grid square, 1 or more points are being selected. I know the issues with subqueries but I have run this exact query on another dataset successfully but when running with this dataset it just doesn't work. Are there any issues with FLOATs or INTs I need to be aware of? I am at my wits end having spent many hours on this problem and I would be so grateful for any pointers.
I would like to upload the personal geodatabase somewhere but not sure how to do this?
Thanks.
Garret
