Subnetwork controller category not appearing in Utility Network
429
02-20-2018 10:04 PM
VikramAundhekar
New Contributor II
I am trying to configure electric distribution Utility network. I assigned partitioned as Tier definition. Now when i am trying to set network category as Subnetwork controller, Subnetwork controller option is not appearing in drop down arrow for device feature class.
HusseinNasser2
Hi Vikram,
In order to set a certain asset (Asset Group/Asset Type) to be a potential subnetwork controller in a partitioned network, you will first need to assign a directional terminal configuration to the same pair. This is critical in the partitioned network not as much in hierarchical.
Hope that helps let us know if you have any more questions and good luck!
-Hussein
