Stop making a line at point without an attribute
407
10-02-2019 12:21 AM
MateuszRatajczak
Hello, I have a set of data with XYZ coordinates. I want to make a line from start to the end, but some points are missing Z data. The Question is. is there a tool or a script where Point to Line will stop at a point with now data and continue from the next one with full XYZ?
I don't want this interpolation to cover the point without full XYZ data.
Any help is welcomed!
NeilAyres
MVP Alum
Sounds like you will need to investigate some python / arcpy magic.
If you can post an example of your data here maybe someone can get you started.
Other info required : what version are you using and what is the coordinate system of the data?
A quick search revealed thing like this :
python - Reading Text File to create Polyline with ArcPy? - Geographic Information Systems Stack Exc...
MateuszRatajczak
So we use CRS - EPSG 3334: Pulkovo 1942(58) GaussKruger Zone 4 and ArcGIS 10.2.
Want I'm looking for is a line that will break each time there is a gap.
Example of data:
4675861.031307 5618099.962198      3 1910.000000
4675853.056280 5618066.666666      3 1910.000000
4675847.638880 5618033.333332      3 1910.000000
4675843.301398 5618000.000000      3 1910.000000
4675843.283591 5617966.666666      3 1910.000000
4675844.345703 5617933.333332      3 1910.000000
4675846.066287 5617898.412698      3 1910.000000
4675850.420755 5617857.142855      3 1910.000000
4675855.433695 5617814.285711      3 1910.000000
4675860.446635 5617771.428569      3 1910.000000
4675865.459575 5617728.571422      3 1910.000000
4675870.472515 5617685.714281      3
4675875.485454 5617642.857140      3
4675879.855671 5617601.587301      3
4675881.654998 5617566.666666      3
4675882.811602 5617533.333332      3
4675879.110538 5617500.560425      3
4675855.978803 5617470.029219      3
4675827.989401 5617440.058438      3
4675797.998233 5617413.826022      3
4675759.999999 5617402.547054      3
4675719.999998 5617395.006448      3 1910.000000
4675679.999996 5617387.465843      3 1910.000000
4675639.999998 5617379.925237      3 1910.000000
4675601.111111 5617370.819957      3 1910.000000
4675566.666666 5617355.455974      3 1910.000000
4675533.333332 5617338.527315      3 1910.000000
4675501.676855 5617320.820324      3 1910.000000
4675476.343842 5617297.791666      3 1910.000000
4675451.151864 5617265.151339      3 1910.000000
4675425.575931 5617230.302678      3 1910.000000
4675401.374914 5617194.227510      3 1910.000000
4675382.673555 5617153.246301      3 1910.000000
4675365.347110 5617111.038583      3 1910.000000
4675348.020665 5617068.830866      3 1910.000000
4675330.694219 5617026.623145      3 1910.000000
4675313.367775 5616984.415429      3 1910.000000
4675296.041332 5616942.207715      3 1910.000000
4675279.548798 5616901.479063      3 1910.000000
4675266.391902 5616866.666666      3 1910.000000
4675254.068916 5616833.333332      3 1910.000000
4675242.543566 5616800.000000      3 1910.000000
4675234.208755 5616766.666666      3 1910.000000
4675226.671580 5616733.333332      3 1910.000000
4675220.169602 5616700.000000      3 1910.000000
4675217.808417 5616666.666666      3 1910.000000
4675216.482430 5616633.333332      3 1910.000000
4675216.112474 5616600.000000      3 1910.000000
4675219.566643 5616566.666666      3 1910.000000
4675223.976845 5616533.333332      3 1910.000000
4675229.122009 5616500.000000      3 1910.000000
4675237.207029 5616466.666666      3 1910.000000
4675246.027012 5616433.333332      3 1910.000000
4675255.935049 5616398.888888      3 1910.000000
4675270.195303 5616359.999999      3 1910.000000
4675285.543612 5616319.999998      3 1910.000000
4675300.891921 5616279.999996      3 1910.000000
4675316.240229 5616239.999998      3 1910.000000
4675332.369078 5616200.000000      3 1910.000000
4675351.620092 5616159.999999      3 1910.000000
4675371.651648 5616119.999998      3 1910.000000
4675391.683204 5616079.999996      3 1910.000000
4675411.714759 5616039.999998      3 1910.000000
4675431.683900 5616001.111111      3 1910.000000
4675451.403393 5615966.666666      3 1910.000000
4675471.060473 5615933.333332      3 1910.000000
4675489.489442 5615900.000000      3 1910.000000
4675503.005975 5615866.666666      3 1910.000000
4675515.294398 5615833.333332      3 1910.000000
4675526.229056 5615800.000000      3 1910.000000
4675531.748657 5615766.666666      3 1910.000000
4675535.914493 5615733.333332      3 1910.000000
4675536.045996 5615702.858389      3 1910.000000
4675520.040165 5615683.817002      3 1910.000000
4675497.784472 5615672.589763      3 1910.000000
4675466.666666 5615681.185554      3 1910.000000
4675433.333332 5615694.737103      3 1910.000000
4675400.000000 5615708.909266      3 1910.000000
4675366.666666 5615725.563890      3 1910.000000
4675333.333332 5615742.839129      3 1910.000000
4675300.000000 5615759.120167      3 1910.000000
4675266.666666 5615771.424402      3 1910.000000
4675233.333332 5615782.734436      3 1910.000000
4675198.888888 5615793.009371      3 1910.000000
4675159.999999 5615799.143914      3 1910.000000
4675119.999998 5615804.243359      3 1910.000000
4675079.999996 5615809.342804      3 1910.000000
4675039.999998 5615814.442249      3 1910.000000
4675001.111111 5615819.949444      3 1910.000000
4674966.666666 5615827.087641      3 1910.000000
4674933.333332 5615834.633588      3 1910.000000
4674900.000000 5615843.137671      3 1910.000000
4674866.666666 5615855.474298      3 1910.000000
4674833.333332 5615868.769062      3 1910.000000
4674800.000000 5615882.796145      3 1910.000000
4674766.666666 5615899.752507      3 1910.000000
4674733.333332 5615917.441188      3 1910.000000
4674698.888888 5615936.089238      3 1910.000000
4674659.999999 5615958.574765      3 1910.000000
4674619.999998 5615982.019662      3 1910.000000
4674579.999996 5616005.464559      3 1910.000000
4674539.999998 5616028.909454      3 1910.000000
4674501.111111 5616051.908847      3 1910.000000
4674466.666666 5616073.126235      3 1910.000000
4674433.333332 5616093.898121      3 1910.000000
4674399.310697 5616115.620644      3 1910.000000
4674362.530850 5616141.145720      3 1910.000000
4674325.061700 5616167.621434      3 1910.000000
4674287.592551 5616194.097148      3 1910.000000
4674250.123400 5616220.572863      3 1910.000000
4674212.654252 5616247.048576      3 1910.000000
4674175.185105 5616273.524288      3 1910.000000
4674137.357595 5616299.724439      3 1910.000000
4674098.096631 5616324.822345      3 1910.000000
4674058.477304 5616349.644689      3 1910.000000
4674018.857978 5616374.467033      3 1910.000000
4673979.238651 5616399.289378      3 1910.000000
4673939.619329 5616424.111719      3 1910.000000
4673901.047666 5616448.874553      3 1910.000000
4673866.666666 5616473.399345      3 1910.000000
4673833.333332 5616497.864626      3 1910.000000
4673799.572039 5616523.187639      3 1910.000000
4673764.098905 5616551.941588      3 1910.000000
4673728.197811 5616581.553271      3 1910.000000
4673692.296718 5616611.164953      3 1910.000000
4673656.395623 5616640.776637      3 1910.000000
4673620.494534 5616670.388316      3 1910.000000
4673585.877319 5616699.755266      3 1910.000000
4673556.395624 5616728.143285      3 1910.000000
4673528.197811 5616756.286570      3 1910.000000
4673501.260988 5616782.334330      3 1910.000000
4673479.590593 5616802.960531      3 1910.000000
4673460.071083 5616833.333334      3 1910.000000
4673424.693184 5616894.444445      3 1910.000000
4673421.477012 5616900.000000      3 1910.000000
4672078.516609 5617421.483391      4 1910.000000
4672071.973558 5617420.993796      4 1910.000000
4672039.258305 5617418.545821      4 1910.000000
4672000.987495 5617415.309105      4 1910.000000
4671966.666666 5617410.875804      4 1910.000000
4671933.333332 5617406.143356      4 1910.000000
4671898.888888 5617401.851812      4 1910.000000
4671859.999999 5617399.323883      4 1910.000000
4671819.999998 5617397.236858      4 1910.000000
4671779.999996 5617395.149832      4 1910.000000
4671739.999998 5617393.062807      4 1910.000000
4671701.111111 5617390.247574      4 1910.000000
4671666.666666 5617384.519513      4 1910.000000
4671633.333332 5617378.063244      4 1910.000000
4671600.000000 5617370.548590      4 1910.000000
4671566.666666 5617358.800393      4 1910.000000
4671533.333332 5617345.993811      4 1910.000000
4671501.100989 5617332.556057      4 1910.000000
4671473.272603 5617316.593615      4 1910.000000
4671447.121005 5617300.110669      4 1910.000000
4671423.272603 5617284.070396      4 1910.000000
4671398.323211 5617265.955561      4 1910.000000
4671366.666666 5617239.099799      4 1910.000000
4671333.333332 5617210.058805      4 1910.000000
4671300.000000 5617181.672452      4 1910.000000
4671266.666666 5617155.904659      4 1910.000000
4671233.333332 5617130.791507      4 1910.000000
4671200.000000 5617108.094212      4 1910.000000
4671166.666666 5617095.060346      4 1910.000000
4671133.333332 5617084.442336      4 1910.000000
4671100.000000 5617076.368332      4 1910.000000
4671066.666666 5617078.470347      4 1910.000000
4671033.333332 5617083.116367      4 1910.000000
4670999.584003 5617090.369633      4 1910.000000
4670934.312930 5617124.959795      4 1910.000000
4670928.341378 5617128.341378      4 1910.000000
4673433.333332 5616662.328534      6 1900.000000
4673400.000000 5616679.755018      6 1900.000000
4673366.666666 5616695.804349      6 1900.000000
4673333.333332 5616711.509391      6 1900.000000
4673300.000000 5616726.985075      6 1900.000000
4673266.666666 5616741.543334      6 1900.000000
4673233.333332 5616755.872236      6 1900.000000
4673198.584687 5616770.296225      6 1900.000000
4673158.174788 5616785.100568      6 1900.000000
4673116.856580 5616800.884234      6 1900.000000
4673077.566383 5616820.204836      6 1900.000000
4673038.783190 5616840.409672      6 1900.000000
4672999.797198 5616857.866748      6 1900.000000
4672959.999999 5616864.332789      6 1900.000000
4672919.999998 5616868.051071      6
4672879.999996 5616871.769354      6
4672839.999998 5616875.487636      6
4672800.444579 5616879.741432      6
4672762.667476 5616886.137279      6
4672725.334952 5616893.068640      6
4672687.583426 5616903.011440      6
4672648.155883 5616925.000000      6
4672608.309336 5616950.000000      6 1900.000000
4672568.462788 5616975.000000      6 1900.000000
4672530.487959 5616999.730591      6 1900.000000
4672499.302296 5617022.678638      6 1900.000000
4672467.197536 5617042.537657      6 1900.000000
4672434.395073 5617061.691772      6 1900.000000
4672401.592609 5617080.845886      6 1900.000000
4672368.524711 5617100.804293      6 1900.000000
4672334.395073 5617123.979874      6 1900.000000
4672300.176956 5617146.730372      6 1900.000000
4672266.666666 5617164.563363      6 1900.000000
4672233.333332 5617181.166977      6 1900.000000
4672200.000000 5617196.990103      6 1900.000000
4672166.666666 5617209.691279      6 1900.000000
4672133.333332 5617221.611968      6 1900.000000
4672100.000000 5617233.124893      6 1900.000000
4672066.666666 5617243.006772      6 1900.000000
4672033.333332 5617252.480888      6 1900.000000
4672000.000000 5617261.557468      6 1900.000000
4671966.666666 5617269.043905      6 1900.000000
4671933.333332 5617276.132805      6 1900.000000
4671900.000000 5617282.659168      6 1900.000000
4671866.666666 5617286.935379      6 1900.000000
4671833.333332 5617290.649051      6 1900.000000
4671800.000000 5617293.619651      6 1900.000000
4671766.666666 5617293.617962      6 1900.000000
4671733.333332 5617292.873201      6 1900.000000
4671700.000000 5617291.053893      6 1900.000000
4671666.666666 5617284.936396      6 1900.000000
4671633.333332 5617277.744352      6 1900.000000
4671600.000000 5617269.068481      6 1900.000000
4671566.666666 5617254.457303      6 1900.000000
4671533.333332 5617238.362297      6 1900.000000
4671500.000000 5617220.525378      6 1900.000000
4671466.666666 5617195.720803      6 1900.000000
4671433.333332 5617169.174313      6 1900.000000
4671400.000000 5617142.067362      6 1900.000000
4671366.666666 5617112.718557      6 1900.000000
4671333.333332 5617082.809289      6 1900.000000
4671300.000000 5617054.474169      6 1900.000000
4671266.666666 5617032.435629      6 1900.000000
4671233.333332 5617011.971235      6 1900.000000
4671200.000000 5616993.680466      6 1900.000000
4671166.666666 5616984.084188      6 1900.000000
4671133.333332 5616976.661533      6 1900.000000
4671100.000000 5616970.837478      6 1900.000000
4671066.666666 5616971.407822      6 1900.000000
4671033.333332 5616973.576766      6 1900.000000
4671000.107933 5616977.405410      6 1900.000000
4670967.314269 5616987.872855      6 1900.000000
4670934.304737 5617000.857477      6 1900.000000
4670901.602712 5617017.118626      6 1900.000000
4670854.144180 5617047.250180      6 1900.000000
4670849.975469 5617049.975469      6 1900.000000
4673565.057103 5616441.307141      8 1890.000000
4673530.114206 5616460.871428      8 1890.000000
4673495.171308 5616480.435714      8 1890.000000
4673458.547469 5616500.085993      8 1890.000000
4673415.199860 5616520.080246      8 1890.000000
4673370.171308 5616540.160492      8 1890.000000
4673325.142757 5616560.240737      8 1890.000000
4673280.114206 5616580.320983      8 1890.000000
4673235.085654 5616600.401229      8 1890.000000
4673190.057103 5616620.481475      8 1890.000000
4673145.028551 5616640.561721      8 1890.000000
4673100.838092 5616659.836233      8 1890.000000
4673059.999999 5616675.887814      8 1890.000000
4673019.999998 5616691.133661      8 1890.000000
4672979.999996 5616706.379508      8 1890.000000
4672939.999998 5616721.625354      8 1890.000000
4672900.000000 5616736.288158      8 1890.000000
4672859.999999 5616748.618794      8 1890.000000
4672819.999998 5616760.366388      8 1890.000000
4672779.999996 5616772.113982      8 1890.000000
4672739.999998 5616783.861576      8 1890.000000
4672701.111111 5616795.994504      8 1890.000000
4672666.666666 5616809.668772      8 1890.000000
4672633.333332 5616823.728375      8 1890.000000
4672598.726504 5616838.900934      8 1890.000000
4672559.025694 5616858.525319      8 1890.000000
4672518.051388 5616879.262660      8 1890.000000
4672477.483045 5616900.778073      8 1890.000000
4672438.538542 5616925.405779      8 1890.000000
4672399.756424 5616950.576591      8 1890.000000
4672359.999999 5616974.807535      8 1890.000000
4672319.999998 5616998.803513      8 1890.000000
4672279.999996 5617022.799490      8 1890.000000
4672239.999998 5617046.795466      8 1890.000000
4672201.111111 5617069.512824      8 1890.000000
4672166.666666 5617087.115715      8
4672133.333332 5617103.439988      8
4672100.000000 5617119.277480      8
4672066.666666 5617133.167852      8
4672033.333332 5617146.571445      8
4672000.000000 5617159.302551      8
4671966.666666 5617169.343717      8
4671933.333332 5617178.712398      8 1890.000000
4671900.000000 5617187.367826      8 1890.000000
4671866.666666 5617193.170249      8 1890.000000
4671833.333332 5617198.259420      8 1890.000000
4671800.000000 5617202.326518      8 1890.000000
4671766.666666 5617202.305320      8 1890.000000
4671733.333332 5617201.262050      8 1890.000000
4671700.000000 5617198.776049      8 1890.000000
4671666.666666 5617190.519129      8 1890.000000
JohannesBierer
Why not creating two lines? One line with the full data, one erase line with the data without z information? Then erase the no data line area?
NeilAyres
MVP Alum
Is that 3rd column (3, 4, 6, 8 etc) a line identifier?
So line 3 would become 2 pieces but the same line ie multipart.
