Matt,
yes, I totally agree with this point. But as I mentioned earlier, in ArcGis9.3, the "Divide" option would split the whole line at the specified distance, although, as you said, accounting generally for a final uneven fragments, which was fine. It had the same wanted output as I do now, but in just one step.
my explanation might not be the best, sorry, but let's say you had a 93 meters line you want to split each 10 meters, I would come up with 10 fragments, 9 of 10m each and 1 of 3m, which is what I am interested in doing with the line.
I was just thinking that a similar tool as "Divide" with the "Split" one, if an extended option of split by distance of multiple segments regardless of the final unevenness, could be made. does it make sense?
anyways, I'm satisfied with my outcome now, just a suggestion.
thank you!
Ariadna
