Spatial reference does not exist in the data source
2863
12
01-12-2021 03:28 AM
hanakohinonn
New Member
  • Hi, Now I have a polygon layer, and I want to convert it to raster.
So, I tried to polygon to raster, however, the error came up with.
ERORR:999999
Spatial reference does not exist in the data source.
I have no ideal to solve this problem, please help me.
Thanks in advance.
DanPatterson
MVP Esteemed Contributor
You need to define its coordinate system first
Define Projection (Data Management)—ArcGIS Pro | Documentation
If you don't know what to define it as,
then don't guess, .... should be, could be, might be...
aren't good options, a misdefined coordinate system will only make a situation worse.
... sort of retired...
hanakohinonn
New Member
Hi, Dan. Thank you for your replying!
Following your advice, I tried define projection. And I got new error.
EROOR:999999
Table name is not correct.
Table is not found.
How do you think why I cannot complete [define projection] and [polygon to raster]?
Any ideal would be help me.
Thank you.
DanPatterson
something is wrong with the file.
Can you add it all by itself to a map and view it? (no basemap, no other data)
Can you open the table?
What are the extents of the file (left, right, top bottom)? check under the layer properties.
What Is the coordinate system supposed to be in light of the extent?  Does it look like decimal degree data? or does it look like it is projected?
SteveLynch
also try running CheckGeometry
hanakohinonn
New Member
Hi, Steve. Thank you for your replying!
I tried CheckGeometry, but I failed to it.
I don’t know  what is the reason.
If you have any idea, please teach me.
Thank you.
SteveLynch
Your polygon layer, is it from a shapefile or a file geodatabase?
Right click the layer to see the properties.
Provide a screenshot showing the map and could you share the data.
SteveLynch
can you use CopyFeatures and copy it into the default file geodatabase and then try using the copied feature class.
hanakohinonn
New Member
Thank you for your advice!
I tried Copy Features ,but it also failed.
I  have no idea  why my shapefile cause a lot of error.  Are  there any solutions?
DanPatterson
What was the actual error?
Did you get the shapefile from somewhere? or did you produce it?
Did you get any errors when loading the shapefile into a blank map?
If Repair Geometry and Copy Features doesn't fix the geometry problems there is little else you can do.
