Show image of a point infowindown
3323
11
09-01-2014 11:34 PM
lasinh
i used query and querytask and  return of type point(only one point), I showed this point with infowindown on the map
how to show the image of a point in the  infowindown from the results returned by querytask ?
RiyasDeen
Hi Ia,
Yes when i say attribute it's the column of the feature class that you see in arcmap.
There has to be someway of identifying the image against feature. It can be an attribute field or a pattern like the images will have the same name as your feature class OBJECTID and will always be placed at a particular folder. This way you can build a logic around this to get your IMAGEURL.
lasinh
my services layer,  there are many points. I can not save sourceURL for each point, please give me a proposal!!! thank you!
