Shapefile Colors based on attributes?
5864
03-31-2014 10:56 AM
GregSullivan1
I have what I think should be a very easy to solve problem but I am struggling. I currently have a shapefile with descriptions of land use cover as one of the columns in the Attribute table. My entire shapefile comes up as one color/shade and I want to make the colors different depending on the type of Land Cover. I have around 1500 features but only 14 different types of land use. Does anyone know how I could do this?
JoshuaChisholm
Hello Greg,
If I'm understanding you correctly, you just need to use layer symbology.
  1. Double-click the desired layer in the Table Of Contents
  2. Go to the "Symbology" tab
  3. Under "Show:", Select "Categories" then "Unique Values"
  4. The "Value Field" should be set to the field you want to symbolize by ('land use cover' in your case)
*Note, a layer's symbology information is stored in the map document (MXD), not the shapefile/geodatadase. Only the data (spatial and attributes) are stored in the shapefile/geodatabase.
JoshuaChisholm
Hello Greg,
GregSullivan1
Thanks, this was exactly what I was looking for!
