Using the sdeping command as well as others and getting the following error.
Error executing command: [sdeping -i sde:sqlserver:p-srv-5,1433 -u fireintell -p kljk -D FireIntell]
Stderr results: [['\r\n', 'ArcSDE 10.0 Connection Test Utility Wed Oct 26 14:22:59 2011\r\n', '
------------------------------------------------------------------------\r\n',
"Error: ArcSde Direct Connect driver release isn't compatible with
ArcSde database instance release (-450)\r\n", '\r\n']]
I have installed SDE10 on both my SQL Server and ArcGis server and applied SP3. I am using se-toolkit binaries for arcgis10 sp2. sp3 not available, yet.
Does anyone else have this problem?
vangelo, are you planning to release a sp3 version of the toolkit?
-b
