SDE file are not working anymore (Oracle DB)
3101
04-07-2023 09:18 AM
Polopolo
Hello, this morning I had a surprise. My services are not working. They are running but not working, if I try to restart them they fail after a while with error:
In english something like 'Construction of service instance 'xxxx.MapServer' failed. Service starting expired.'
I cannot validate the SDE files from this DB in AGS.
In ArcCatalog, I don't have any error but my Catalog cannot connect to sde, it just tries to connect to DB indefinitely.
In sqldev, no problem to connect to the DB, everything works fine.
Another DB is on the same server and it works perfectly fine too.
I really don't know what could cause this behavior, do you have any idea? Or places i could find more info?
Tags (3)
DavidPike
MVP Notable Contributor
Everything licensed ok?
MarceloMarques
Log into the ArcGIS Server Machine and check the following.
1. open a cmd window and try to ping the database server e.g. " ping mydbserver1.acme.com"
ping shall show it can reach the database server
2. try to connect to the database using the database tool
Oracle - use Oracle Instant Client / Oracle Full Client - SQL Plus or Oracle SQL Developer
4. Open ArcGIS Server Manager > Sites > Datastore and click Validate All
Then from another machine running ArcGIS Pro try to connect to the geodatabase.
connect with the sde user and make sure the property is checked for "geodatabase accepting connections"
If you still cannot connect, then ask your Oracle DBA to check if the database datafiles  are not full and need more space. The database administrator can diagnose database connection issues easily and make the correction necessary for the oracle database connections to work again.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
ChrisUnderwood
Using ArcCatalog you can create a connection log file if you add a couple of Environment Variables like this.
SDESVRLOG      TRUE
SDESVRLOGLOC   C:\Users\username\Documents (or similar location)
Make sure you have OK'd the Environment Variables form, and restarted ArcCatalog. The file will be called sdedc_Oracle.log
MarceloMarques
This can also help diagnose the problem.
How To: Diagnose ArcSDE Connection and Performance Issues Using SDEINTERCEPT (esri.com)
Polopolo
It was a database problem which was really slow to connect (so I guess ArcCatalog got a timeout but the UI made me thought it was still trying to connect). After restarting the VM, it is working fine
