I added a field to a one way replica and then populated it with values. Then I followed the schema change instructions - compare schema and then import the changes and this added the field to my child replica. The problem is the values are all nulls. Synchronizing the data does not populate the new values. I tried an experiment where I moved one point slightly and synchronized changes and that worked to populate the new field for that one point only. I could move all of my points a hair but there has to be a better way than that to transfer the values in this field. Right?
