Schedule for ArcSDE 10.3 release?  (for NIM-099594 issues)
6658
11
04-09-2014 10:07 AM
EllenDean
Hello -
Does anyone have information as to when ArcSDE 10.3 is scheduled for release?  We are beginning to have big problems with a known bug (NIM-099594) which is supposed to be fixed in 10.3.
Links to NIM-099594 and Knowledge Base article:
http://support.esri.com/en/bugs/nimbus/TklNMDk5NTk0
http://support.esri.com/en/knowledgebase/techarticles/detail/42335
Our current system:
Oracle 11g (11.2.0.1) - Linux RedHat 5.4 64-bit
ArcSDE 10.1 sp1
using ST_Geometry format
Our ArcSDE upgrade path has been:  (1)  9.3.1  (2) 10.0 sp5  (3) 10.1 sp1
My understanding is that the issue happens when ArcSDE is upgraded from 10.0 to 10.1.  If ArcSDE is upgraded from version 9.3.1 directly to 10.1 it doesn't happen.
The only work-around we've so far been successful with is to create new feature classes for the ones having this problem and load in the data from the original feature class.
We are also curious if others are running into this problem.
Ellen Dean
St. Johns River Water Management District
chandesrisbasile1
Note:
http://forums.arcgis.com/threads/106418-ArcGIS-Server-10.22-Identify-Issue
http://support.esri.com/en/bugs/nimbus/TklNMTAxNDEw
Now it seems more the "Bug:  Unable to insert or update Oracle st_geometry feature classes, encountering ORA-20085 errors"
http://support.esri.com/en/knowledgebase/techarticles/detail/42461
issue NIM095988 (http://support.esri.com/en/bugs/nimbus/TklNMDk1OTg4)
It is marked as solved in Nimbus, but with no solution in the bug report(?).
chandesrisbasile1
great a patch is now available for 10.2.2:
ArcGIS 10.2.2 for (Desktop, Engine, Server) Spatial Reference Consistency Patch
Date Published: 06-24-2014
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/67/metaid/2098
