Hi Geoff,
thanks for your help. Our customer needs an extension, which is able to copy nautical data from their custom system to a SDE. The current data formats are shape and S-57. The extension should be able to create layers in ArcMap automatically. No problem for shape files, but how can S-57 layers be created with C#? The data should be read only.
In my mind, two solutions may be found: (a) create a layer directly with a S-57 file as data source or (b) convert the S-57 to geodatabase, sde, and then create a layer from the gdb-featureclass(es)
btw: the created layers and the mxd file are used for creating a MapService in ArcGIS server afterwards
I hope you can give me any hints.
Best regards, Stefan
